06-03-2007, 10:22 AM
tigershark help
Don't know if anyone will know this or not but I have a 97 Tigershark Monte Carlo 770 and when it idles it only fires on one cylinder and when you hit the throttle the second cylinder picks up and the ski runs fine I pulled the plugs yesterday and they were pretty black and I put some fresh ones in...any ideas?
I BLEED GREEN
2002 ARCTIC CAT ZR 500
1993 SKI DOO MACH 1
1991 ARCTIC CAT EXT 530
06-03-2007, 03:01 PM
Put a spark tester on each plug to make sure you have spark. If you do, I'd say compression is low on one side. Should be at least 130 lbs or so.
06-03-2007, 03:08 PM
I haven't run it since the new plugs went in I'm going on Wednesday. Hopefully it will be an easy fix...it just weird it runs fine when you give it throttle you can feel when the second cylinder kicks could the dirty plugs cause it? this is my first jet ski so I don't know much about them
06-03-2007, 07:22 PM
It may be flooding out on that side at idle. Check to see if that plug is wet and fuel soaked. Do a compression test to make sure it has good compression first. You need to eliminate the easy things first.
06-03-2007, 08:33 PM
how do you do a compression test on a jet ski? It's not in water right now and is electric start
06-04-2007, 08:06 AM
SENIOR MEMBER
<correct me if im wrong> but remove one plug and put in the compression guage. try to turn it over and read the max psi. then do the other side.
The Original Logo -> GALLERY UPDATED with 2007 Photos
SF.com 3rd Annual Michigan Ride: FEB '08: Presidents Weekend
06-08-2007, 09:06 AM
ok so It seems I'm not getting any fuel to the plugs....I checked the line and its in there....could it be carbs or anything?
I BLEED GREEN
1993 SKI DOO MACH 1
06-09-2007, 06:07 AM
SOunds like the idle circuit on that cylinder's carburetor is AFU. Remove and clean the carb.
06-14-2007, 10:17 AM
SEG, does AFU stand for what i think it does?  im just wondering
2003 Yamaha SxViperER-rumblepack can, XENON headlights
1993 Polaris XCR 4409(for sale)
2003 Polaris MSX 140 H.O.
1999 Larson LXi 220H.P.-s.s. prop, CD player, Xplod subs, Xplod amp
1996 Dodge Ram 1500-2 inch body lift, amp, subs, duals, CBw/ 4foot whips, american racing ventura rims
06-15-2007, 06:00 AM
Yes it does.....
06-16-2007, 12:25 PM
ah ic lol. at work, if we get a part that is no good, we send it back, labled NFG
06-18-2007, 08:10 PM
SENIOR MEMBER
LMAO
06-22-2007, 12:41 PM
I got it workin dead battery plus the carbs needed to be reconfigured thanks guys!
