Go Back   Snowmobile Forum: Your #1 Snowmobile Forum > Automotive and Other Sport Forums > Watersports Forum
Old 06-03-2007, 11:22 AM   #1 (permalink)
headbanger7483
headbanger7483's Avatar
tigershark help
Don't know if anyone will know this or not but I have a 97 Tigershark Monte Carlo 770 and when it idles it only fires on one cylinder and when you hit the throttle the second cylinder picks up and the ski runs fine I pulled the plugs yesterday and they were pretty black and I put some fresh ones in...any ideas?
I BLEED GREEN
2002 ARCTIC CAT ZR 500
1999 ARCTIC CAT ZL 500efi
1993 SKI DOO MACH 1
headbanger7483 is offline   Reply With Quote
Old 06-03-2007, 04:01 PM   #2 (permalink)
Put a spark tester on each plug to make sure you have spark. If you do, I'd say compression is low on one side. Should be at least 130 lbs or so.
Old 06-03-2007, 04:08 PM   #3 (permalink)
headbanger783
I haven't run it since the new plugs went in I'm going on Wednesday. Hopefully it will be an easy fix...it just weird it runs fine when you give it throttle you can feel when the second cylinder kicks could the dirty plugs cause it? this is my first jet ski so I don't know much about them
headbanger783 is offline   Reply With Quote
Old 06-03-2007, 08:22 PM   #4 (permalink)
It may be flooding out on that side at idle. Check to see if that plug is wet and fuel soaked. Do a compression test to make sure it has good compression first. You need to eliminate the easy things first.
Old 06-03-2007, 09:33 PM   #5 (permalink)
headbanger783
how do you do a compression test on a jet ski? It's not in water right now and is electric start
Old 06-04-2007, 09:06 AM   #6 (permalink)
PolarisINDY500
SENIOR MEMBER
PolarisINDY500's Avatar
<correct me if im wrong> but remove one plug and put in the compression guage. try to turn it over and read the max psi. then do the other side.
The Original Logo ->
Old 06-08-2007, 10:06 AM   #7 (permalink)
headbanger7483
ok so It seems I'm not getting any fuel to the plugs....I checked the line and its in there....could it be carbs or anything?
I BLEED GREEN
1993 SKI DOO MACH 1
Old 06-09-2007, 07:07 AM   #8 (permalink)
SOunds like the idle circuit on that cylinder's carburetor is AFU. Remove and clean the carb.
Old 06-14-2007, 11:17 AM   #9 (permalink)
sxviper700
SEG, does AFU stand for what i think it does? im just wondering
FIREFIGHTER
2003 Yamaha Viper
2005 Suzuki GSX-R600
1995 Larson LXi 174
1996 Sea Doo SPX
1996 Dodge Ram 1500 Off Road
sxviper700 is offline   Reply With Quote
Old 06-15-2007, 07:00 AM   #10 (permalink)
Yes it does.....
Old 06-16-2007, 01:25 PM   #11 (permalink)
sxviper700
ah ic lol. at work, if we get a part that is no good, we send it back, labled NFG
FIREFIGHTER
2003 Yamaha Viper
1995 Larson LXi 174
1996 Sea Doo SPX
Old 06-18-2007, 09:10 PM   #12 (permalink)
PolarisINDY500
SENIOR MEMBER
LMAO
Old 06-22-2007, 01:41 PM   #13 (permalink)
headbanger783
I got it workin dead battery plus the carbs needed to be reconfigured thanks guys!
