Old 11-17-2005, 12:05 AM   #1 (permalink)
MTSNOWSLAYER
Carb assembly Arctic Cat El tigre 530cc
I am learning to work on my sled myself with an old smei good shape 89 el tigre. I cleaned the carbs and now need to re-assemble them. I concerned about getting the tiny snap ring bac in the proper place. let me know if ther eis literature I can use or if its just simply snapped back in place. Also, the gas and oil and water lines look old, those should probaly replaced for a tighter fit? Thanks a lot, I appreciate any response.
MTSNOWSLAYER is offline   Reply With Quote
Old 11-17-2005, 03:14 PM   #2 (permalink)
SnowRida
Runnin Against The Wind!
SnowRida's Avatar
Post this in the Arctic Cat section. You should get better replies.
SnowRida
Yamaha V-Max
02 MXZ 600
97 Polaris Indy Trail Touring
Old 11-18-2005, 09:29 PM   #3 (permalink)
JEFFH
JEFFH's Avatar
Which snap ring? where does it go?
JEFFH is offline   Reply With Quote
Old 11-19-2005, 06:28 AM   #4 (permalink)
IndianRvrShiver
IndianRvrShiver's Avatar
Assume you're talking about the tiny snap ring that retains the main jet needle in the slide. There are 3 grooves in the top of the needle, stock position is the middle groove; top groove (lowering the needle) is leaner; bottom groove (raising the needle) is richer.
If you have any doubt about the hoses/lines, just replace them. If not, you can bet they will fail at the most inopportune time.
Good luck!
