Correct spark plug for Roatx 399 - Just to document.
I'm not looking for responses, I just want to document the problem I was having along with the solution so maybe I can save someone else some pain.
The sled in question is a 1972 399 Olympic. The machine constantly fouled plugs, hated to idle and was generally a reluctant runner - always took lots of pulls to start, very sensitive to over oiling its gas. A real pain in the butt.
It had been professionally rebuilt after a carb fire with new wiring harness, coils, plug wires and plugs. It had B7HS plugs in it (according to the manual). It has a Tillotson carb, not sure if it is original. I had tried cleaning and adjusting the carb with no real difference in the way it ran.
I found another one that is a real runner. Always starts, never complains, even with a Tillotson carb and year old gas. The difference - the plugs! They were B8HS.
Changed the complainer over to B8HS, it started on the first pull! What a difference 1 heat range made. So for reference, use B8HS plugs in a 399 Rotax!
1973 Elan
1982 Blizzard 9500 (being restored)
1990 Mach 1 (gone but not forgotten)
1980 Citation SS (on Cow Island)
