do you have a stock bombardier drive clutch on it?
those clutches were junk in my opinion. a comet 102c is more easily adjustable and parts are readily available for them.
what are you going to do with this 9500 blizzard? drag racing? if thats the case, raise your engagment up closer to 5000 rpm, it will come out of the whole and yank your arms off in the process. you want these motors to top out at 8800 rpm -9000 rpm on a stock motor/pipes set up.
if you want to go all out, have the head shaved to get less squish (more compresion) to .040-.050 thou squish. install a set of Aaen race pipes and a set of 40 mm mikuni carbs. remove the stock air box. stud the track and run 110 octane race fuel with premix. install a carbon fibre race rotary valve then hang on!
'71 Arctic Cat Panther 399
(2) '77 Yamaha srx 440's
'75 Yamaha GPX 433
'77 Arctic Cat Kitty Cat
'81 skidoo 9500 Blizzard
'82 skidoo 9500 Blizzard
'83 skidoo 9700 Blizzard
'99 skidoo MXZ 600
'06 skidoo GTX 500SS
