73 Arctic Cat Cheetah track removal - Snowmobile Forum: Your #1 Snowmobile Forum
Old 01-13-2013, 08:11 PM   #1 (permalink)
I have a 1973 Arctic Cat Cheetah and I am wondering if someone knows of a tutorial,video, or can right something up to guide me through removing the track on it.
Probaly will be posting more about help with this thing so thanks in advance
Xman98 is offline   Reply With Quote
Old 01-14-2013, 04:33 AM   #2 (permalink)
Real simple.
You would start by opening the chain case and removing the chain and lower sprocket.
Then remove the 4 bolts holding the skid [rear suspension] in.
Then you remove the three bolts from the bearing carrier plates on both sides of the tunnel
You then slide the drive shaft over and drop one end down so it can slide out.
You have now removed the track and drives.
This is also the best time to change any bearings that are rough turning or feel wobbly.
Old 01-14-2013, 07:47 AM   #3 (permalink)
Originally Posted by RJ Gleason View Post
Real simple.
Thanks will try to do that today
Old 01-14-2013, 05:54 PM   #4 (permalink)
RJ,
I don't have one to look at but wouldn't there be a track tensioner to be backed off somewhere in there? I need to pull my '71 apart at some point and do the bearings...
Raising sleds from the dead in north central MA.
'70 Ski-Doo Olympique 12/3 - The Yellow Bullet
'71 Arctic Cat Panther 303 - Wankle Panther
'78 Arctic Cat Pantera 5000 - Back from the dead!
'79 Polaris Cobra 340 - Back from the dead!
'95 Ski-Doo Grand Touring SE 670
www.deadsledwrenchers.net
curtludwig is offline   Reply With Quote
Old 01-14-2013, 08:41 PM   #5 (permalink)
Hey thanks guys i got it off today!!!!
