01-06-2013, 11:37 AM
#41 (permalink)
With dyno proof too in the article!
01-06-2013, 11:41 AM
#42 (permalink)
Of them running a air box or pods or no filters? No filters will out dyno a air box or pods any days. We will throw pods on our sled of its really dusty or lots of snow dust. But a air box makes the best power on the trail as it provides cool air. But modifying it will not hurt performance and the air box does not help with fuel mixture or anything else
01-06-2013, 11:42 AM
#43 (permalink)
You need a shop vac to vac that mess out!
'93 Polaris Indy 500 EFI
'79 Arctic Cat Jag 2000
2012-2013 miles - 345
01-06-2013, 02:06 PM
#44 (permalink)
Whats a pod? lol I ended up opening up my air box (with some minor persuasion) and cleaned it out. I plan on using it.
It also warmed up above freezing today (its actually slightly raining) so I was able to get the rest of the mouse nest out. Ill post some pics later.
01-06-2013, 04:39 PM
#45 (permalink)
01-06-2013, 04:49 PM
#46 (permalink)
01-06-2013, 04:53 PM
#47 (permalink)
01-06-2013, 04:58 PM
#48 (permalink)
01-06-2013, 05:05 PM
#49 (permalink)
and another question: Anybody know what this thing is? kind of hard to see with it covered in dirt:
Im wondering if its a ballast for the lights? It has what looks like a ground wire bolted to it, then 2 wires coming out of the side connecting to the wire harness which seems to lead to the lights?
01-06-2013, 06:59 PM
#50 (permalink)
Not a ballast, it's the voltage regulator.
The strap at the front of the skid is the limiter, it prevents the rails from dropping to far when the suspension is at full extension and also can be used to increase ski pressure by shortening slightly.
The shock are most likely frozen due to water getting in them. You will have to replace them.
01-06-2013, 07:00 PM
#51 (permalink)
Hard to tell by pic but it should be voltage regulator
01-06-2013, 07:58 PM
#52 (permalink)
01-06-2013, 11:02 PM
#53 (permalink)
For that rubber connector, some super glue will fix that right up.
01-07-2013, 06:55 AM
#54 (permalink)
It's so much easier to work on a clean sled.
How is the carb coming?
01-07-2013, 10:20 AM
#55 (permalink)
The carb is being a bit stubborn at the moment. I cant get the pin out to get access to the jet. I tried needle nose pliers, lubricating it in carb cleaner then pulling with needle nose pliers, then finally I tried tapping it with a small nail and hammer (gently) but it would not budge.
I am wondering if I could use some penetrating oil (PB Blaster) to loosen the pin, or would that not be a good idea?
Any ideas?
01-07-2013, 10:57 AM
#56 (permalink)
I went ahead and applied PB Blaster to the pin and let it soak for a bit, then tried the pliers and tapping it out, but it still wont move.
01-07-2013, 11:08 AM
#57 (permalink)
Put it in a dish and spray it and let it soak for a hour.
01-07-2013, 11:21 AM
#58 (permalink)
Its still soaking from the last application. Did some research and I guess it would help if I had a spring loaded center punch. I might buy one today if its cheap enough. I also have to be careful not to break the posts, so no more hammering lol
01-07-2013, 02:52 PM
#59 (permalink)
Got a pair of side cutters?
Use them to get behind the shoulder of the pin and apply pressure while gently working om the other end with a punch.
This will require an extra set of hands.
01-08-2013, 10:50 AM
#60 (permalink)
No side cutters or anything thats thin enough to get behind the pin head. I picked up an auto center punch and tried that, but still wont budge, so I soaked it again in PB Blaster, then Ill try what you said (using both pliers and the punch) and hope for the best.
