Got the Spring installed need adjustment help
Well it took a while but we got the spring for the driven clutch and installed it. I did place it in the the number three hole (the one that is was in when removed). There only seemed to be one hole in the opposing side of the clutch so that is where it went. I then then slide the helix onto the shaft and turn it 1/3 of a turn to tighten the spring and then pushed the helix on the rest of the way and installed the clip and bolt. After reinstalling the belt we started he up and went for a ride. It works fine but... It does seem to rev to high at too low a speed. I have no way to judge rpm other than sound, but it just seems high. I am assuming I need to move the spring to a different hole on the helix. The assumption is that it needs to go into a lower hole, is this correct? Does anyone know what the factory setting is on a 75 Panther
Once agin thanks for all your help guys.
