Crankcase torque specs for trail cat? - Snowmobile Forum: Your #1 Snowmobile Forum
Old 12-21-2012, 01:50 PM   #1 (permalink)
10 mm and 12 mm bolts. Anyone know the torque specs and pattern? I was looking at similar sleds, buy the patterns and bolts sizes were different.
This is 340 Spirit Engine.
freaknyea is offline   Reply With Quote
Old 12-21-2012, 02:26 PM   #2 (permalink)
I think I figured out the torque part of it. I wasn't measuring bolt, rater the head. I have 6mm and 7.5mm bolts. I torqued to 7 & 16 ft lbs.
I tried to follow a logical torque pattern, or so I think.
Old 12-21-2012, 02:32 PM   #3 (permalink)
Torque pattern is do the large bolts first, then do the smaller ones starting at the center and work to the outsides in a crossover pattern, then redo the large ones.
Old 12-21-2012, 10:31 PM   #4 (permalink)
I just fix 'em...
IRONDOG's Avatar
Those are 8mm bolts, not 7.5mm. Run them up to 18-20 ft.lbs.
www.snowmobileswapmeet.com
