Yes, adjusting bolts behind the rear guide wheels. The heads face toward the front of the machine. The old machine had a tool kit that came with it with the wrench to adjust the track, but a deep 14 mm socket for the jam nut and a 12 mm socket for the adjusting bolt should do.
Next, rev it a little bit, and check for alignment. Yamaha uses the spec of 1.5" of deflection with a 22 lbs pound weight on it, although I find that too tight. I keep mine at 1.5" with a 10 lbs weight fine, and never had it ratchet.
My Current Sled:
Old Iron:
2012-2013 Miles: 1739
