07 440x Carb on a et340 - Snowmobile Forum: Your #1 Snowmobile Forum
Old 12-10-2012, 12:54 PM   #1 (permalink)
This must have been done by someone but I can't find any information. I want to replace my stock Butterfly type carb from my Et 340 for a flat slide Mikuni it came off a mxz440x. I only plan on using one this season but I would like to know which jets (only close) and part numbers I would be running I will also need needle jets, jet needles, pilots, power jets, the whole nine yards. I realize that I am asking a lot but any input is invaluable, also I recognize I will have to do plug checks and re-jet.
BlueSmoke199 is offline   Reply With Quote
Old 12-11-2012, 09:55 AM   #2 (permalink)
Okay I picked up a 330 300 and 270 main the pilot is a 25 and ordered a trail needle. I will need to route a primer plunger in also. What fuel pump should I use?
Old 12-11-2012, 12:07 PM   #3 (permalink)
The rectangle one should have enough capacity for a single of that size.
Old 12-11-2012, 01:39 PM   #4 (permalink)
RJ or anyone can you make a suggestion about how to make a throttle cable work..
Old 12-11-2012, 04:17 PM   #5 (permalink)
You will need one with a split in it for the oil pump.
One for the MXZ should work.
Old 12-12-2012, 01:35 PM   #6 (permalink)
Thanks RJ
I am running premix tho. The cable that came with the carbs is way too short I have been using a honda thumb throttle and a Ovation carb up till now. I would keep using the cable if it would fit the slide but it won't... Ideas?
Old 12-12-2012, 03:09 PM   #7 (permalink)
Measure the length needed and add at least 2".
You should be able to find one the right length.
Old 12-18-2012, 09:42 PM   #8 (permalink)
I started at a 330 went to a 300 and then a 270 have it running ok at one needle clip up (down) from centre but @ 8C I can't dial it in. Also had the primer plumbed in and the throttle cable made thanks to Dave at Titan cycle. Pilot is a 25 also
