'71 TNT Track Removal? - Snowmobile Forum: Your #1 Snowmobile Forum
Old 07-29-2012, 03:33 PM   #1 (permalink)
geminimissions's Avatar
Question '71 TNT Track Removal?
I'm working on restoring a '71 TNT chassis over the summer but have run into a problem when trying to remove the drive axle and track. I have looked up a manual and read this.. " 5. Tip snowmobile on its side and remove 3
capscrews securing end bearing housing, it may be necessary to pry housing from frame with 2 large screwdrivers." The only problem is the housing seems to be welded to the shaft and I can't pull it through. I already removed the chaincase and have the shaft out of that end. Am I doing something wrong?
geminimissions is offline   Reply With Quote
Old 07-30-2012, 05:13 AM   #2 (permalink)
You are right on track. The shaft should come out of that bearing cup.
1999 Ski Doo Grand Touring
Old 08-01-2012, 01:55 AM   #3 (permalink)
mikemalibu's Avatar
The shaft that's welded to the bearing cup I believe is the spedometer shaft. The bearing and shaft are inside that cup. May be a bummer but it should come off the shaft.
94 indy storm - my hot rod
03 yamaha venture - hers
82 panther - my collector
95 xlt 600- kids sled
mikemalibu is offline   Reply With Quote
