Home made clutch pulling.
I bought a spare motor that came with a Comet 102 C clutch on it.
I have never pulled a primary clutch before, but was aware that they make special tools for doing this. I didn't have one so I decided to fabricate one. I took a long bolt that fit inside the threads on the end of the crank. I had to grind the head slightly to get it to fit into the clutch. I then got a bolt that fit the threads on the clutch(in this case 3/4" fine thread) Put the bolt long bolt inside the clutch and then tightened the big bolt. Clutch popped off.
This seemed to work fine and appears that I can fabricate others, for different clutches/cranks, by just getting the correct size bolts for the units I am working on.
Bolts are a lot cheaper than the special tools.
Any reason not to do this?
Thanks, Joel
