340 enticer fuel issues
I have a 78 enticer 340 and I cant get it to stay running. It wont start without a shot of starting fluid, wont idle, and constantly bogs. I have gone through the carburetor and the jets are clear, the needle is seating, the float is not bent. It doesnt have the original air box on it but it does have an air filter on it. The choke is clean and isnt sticking, the cylinders have 100-110lbs in each of them, it has good spark. The fuel lines are clear and the filters are not clogged. I am stuck. Is it possible the fuel pump could be mounted wrong or is hooked up wrong? It has the mikuni round feul pump. Suggestions please!
