Old 10-20-2009, 04:08 PM   #1 (permalink)
Joelk
Electric Shock when touching carb?
A friend was helping me work on my 79 El Tigre. We had it running and he touched the carb and got a slight shock. He touched it again and said it shocked him pretty hard. Said it was not like a shock directly from Spark Plug Wire but a pretty strong shock.
Everything was dry and the plug wires were not contacting the motor or carb anywhere.
Any idea what would cause this and how to fix?
Thanks, Joel
Joelk is offline   Reply With Quote
Old 10-20-2009, 04:24 PM   #2 (permalink)
leakage at the wire end cap.
Old 10-20-2009, 08:21 PM   #3 (permalink)
Joelk
The plug wires have brand new NGK ends on them, installed with an ample amout of dielectric grease.
These are the NGK wire ends made of hard plastic with rubber seals. Do they not work well?
Any other suggestions how to cure?
Old 10-20-2009, 09:22 PM   #4 (permalink)
Polaris87
Polaris87's Avatar
dont tune carbs when engine is running hahahah. Don't you read warning stickers?...
"Never operate snowmobile with engine hood open."
1995 Polaris 600 XLT Touring
1995 Polaris Indy 500
Polaris87 is offline   Reply With Quote
Old 10-21-2009, 09:42 AM   #5 (permalink)
Ultrafrozen
Ultrafrozen's Avatar
Maybe you ran over the trouble light electrical cord!
1994 Skidoo Grand Touring 580
1997 Polaris Indy 500 classic
Ultrafrozen is online now   Reply With Quote
Old 10-21-2009, 06:39 PM   #6 (permalink)
Check where the wires come out of the mag, you might have a bare wire.
Old 10-22-2009, 09:29 PM   #7 (permalink)
Joelk
All the wires appear to be in great shape and the insulation is completely intact. Could be bad inside the engine, but all wires outside the motor look good.
Old 10-22-2009, 09:46 PM   #8 (permalink)
The coil could be cracked/arcing. Run it with all lights off in a dark area to see if you can see the arc.
Old 10-22-2009, 09:55 PM   #9 (permalink)
Waters88
Waters88's Avatar
I agree with smallengineguy, I had that exact issue with my 72 polaris 340... tested it outside in the dark one night after a while, and could see the blue streak jumping around.
OFSC Trail Patrol Member
1998 Yamaha Vmax 600- 20,000KMs and still tickin'
2002 Yamaha Viper- Sled-4000KMs, Motor- 2400KMs
1973 Polaris Colt 340
1996 Ski-Doo Formula 670- Broken all the time
1999 Yamaha Wolverine 350-Quad
Waters88 is offline   Reply With Quote
Old 10-23-2009, 02:29 AM   #10 (permalink)
Another way to test it is to take a spray bottle with water and gently spritz the wiring, if it starts to stumble or run rough, you have found the problem.
Old 10-23-2009, 08:36 AM   #11 (permalink)
Joelk
Thanks for the replies.
I'll try the operation in the dark, and/or water spray.
If I see/find arcing coming from the plug wires, is there a cure that is less expensive than replacing the coils? (wires permanently attached to the coils)
Would a couple layers of heat shrink tubing provide good insulation?
Old 10-23-2009, 09:39 AM   #12 (permalink)
That would work, and if you ever do replace the coil, put some on the new one to prevent rubbing of the wire.
Old 10-23-2009, 10:00 PM   #13 (permalink)
You can pick up new coils, wires and all for about $25 ea.
Old 10-24-2009, 09:35 AM   #14 (permalink)
Joelk
I assumed the coils would cost a lot more than that, but have not checked.
I assume $25 is for aftermarket coils?
Are the aftermarket coils good quality?
What are the best places to get good prices on parts like these?
Old 10-24-2009, 07:05 PM   #15 (permalink)
Welcome to Shade Tree Powersports - Your One-Stop Parts, Accessories and Apparel leader for Snowmobiles, ATV, Watersports, Harley-Davidson® and Metric
