I am new to the boards and actually do not own a sled. Instead I have a 440 Motor out of an old panther that I am putting into a buggy.
My question is this. Does anyone make a flange adapter for the carb so that I can clamp on a K&N Filter? The carb has 3 bolt hole in it I assume for an airbox.
Thanks.,
watkins is online now Report Post Edit/Delete Message
Otherwise I am not really seeing any adapters for my carb. I see plenty of rubber intake flanges to accept a different carb, but nothing from carb to filter.
That is actually just a screen and stack that go on the carb.
You could probably make an adapter that would work. Just need a plate and ring wide enough for the filter to clamp onto.
