73? Suzuki Nomad 292 one lunger - Snowmobile Forum: Your #1 Snowmobile Forum
post #1 of 15 (permalink) Old 04-07-2009, 10:15 AM Thread Starter
Anyone know where I can get a piston for one of these?
5thcorps is offline
post #2 of 15 (permalink) Old 04-07-2009, 06:59 PM
Smile 73 suzuki nomad 292 one lunger
Het there,what type of motor is in the sled?You might be able to get a piston at dennis kirk or al:s snowmobile parts where are you from?I am in canada i use Royal Distributing.They will send you a free catalog and if its not in there give them a call.They have a toll free number1-800-265-2970 just look on the engine shroud for the mfg name of the engine.Good luck and hope this helps.
gbryanton is offline
post #3 of 15 (permalink) Old 04-08-2009, 06:45 AM
It is a Suzuki engine.
Bore is 2.87" (73mm)
Stroke is 2.76" (70mm)
20hp @ 6000 rpm
Mikuni VM32SH carb
ET magneto
Spark plug NGK B7-HS gapped at 0.024/0.028
Mix ratio 20:1 using Dino oil (should be able to safely run 40:1 synthetic or synth blend oil)
post #4 of 15 (permalink) Old 04-08-2009, 03:12 PM Thread Starter
Here's a pic of the bad boy I'd like to get running again. Like said above it is a Suzuki 292. Would love to find a piston or even another running 292 for it.
5thcorps is offline
post #5 of 15 (permalink) Old 04-08-2009, 03:20 PM
Well, it is a Suzuki engine, you should be able to get the piston online from any of the retailers that stock parts for older sleds, or even from an AC dealer since that engine was used also in the mid '80s models.
post #6 of 15 (permalink) Old 04-08-2009, 03:58 PM Thread Starter
So the Arctic Cat 292 is a Suzuki engine and the parts are interchangable?
5thcorps is offline
post #7 of 15 (permalink) Old 04-08-2009, 07:50 PM
The early arctic cat 292s were Kawasaki engines. Arctic cat switched to Suzuki engines for the 1976 model year.
articcatbill is offline
post #8 of 15 (permalink) Old 04-09-2009, 06:59 AM Thread Starter
So are they the engines and same parts as the 73 nomad? If they are then that could be my answer
5thcorps is offline
post #9 of 15 (permalink) Old 04-09-2009, 07:39 AM
Should be, just take the specs that I listed to be sure.
post #10 of 15 (permalink) Old 04-09-2009, 01:12 PM Thread Starter
Do you know of any specific models that used the 292? I've been searching but can't find any listed.
5thcorps is offline
post #11 of 15 (permalink) Old 04-09-2009, 01:31 PM
Jag or Puma or Panther
post #12 of 15 (permalink) Old 04-13-2009, 11:50 AM Thread Starter
Can not find anywhere that those sleds ever used the 292 suzuki. Does anyone out there have an Arctic Cat with the 292 Suzuki engine? Would really love to get this machine running.....
5thcorps is offline
post #13 of 15 (permalink) Old 04-13-2009, 01:47 PM
I did some research on it also, and was not able to find it used. A 275 and a 250, but not a suzuki 292.
One place I used the ngksparkplugs.com site since it let's you search by engine, and the only 292 arctic cats it shows are the kawasaki's. Granted it doesn't always have everything but it has helped me before to find where other engines were used, it is pretty complete. Did show the 292 suzuki...
So sorry didn't have much luck either, can check a couple books tonight and post if I find anything.
post #14 of 15 (permalink) Old 04-13-2009, 08:53 PM
ice is nice!
snomobum's Avatar
Think I've got you on the right track, Erik...still will have to find the rings, etc, but the right piston's a start. Since I run one of these 'ol blisters, let me know if you should need more info. Happy to help if I can!
Phil
Sled fleet:
'04 AC T660 Turbo Trail
'04 AC Sabercat 600 EXT
'98 AC ZRT 600 (still in rehab process..)
'74 Mercury S/R 440, 'the rat'
'73 Suzuki Nomad 292 one-lunger
'71 Ski-Doo Olympique 399E (needs a piston)
'70 Allouette with a Sachs 290 single (it was free!)
snomobum is offline
post #15 of 15 (permalink) Old 04-13-2009, 10:40 PM
You should be able to cross reference the original plug # to a new replacement #.
