Old 09-18-2008, 05:06 PM   #61 (permalink)
ponchonutty
ponchonutty's Avatar
Yeah maybe this weekend I'll tear apart the carb and make sure it's all OK inside or I might even buy a rebuild kit if I make it into town.
Just a poor man trying to ride a cheap sled
ponchonutty is offline   Reply With Quote
Old 12-21-2008, 02:10 AM   #62 (permalink)
Worley91
Ok. Sorry to bring this one back. However I'm new to the scorpion game. I recently bought a 77 whip 440 that has 539 miles on it. However It has been sitting with gas in it for 10+ years. I recently went through and replaced all the lines and hoses. and ran the feed line to the carb into a gas tank, and it will start and fire fine but as soon as you try to take it above 1500 rpm it bogs out and dies. I've had the carb apart and cleaned it thoroughly and put new plugs on it but it still does the same thing. So any help would be appreciated on what's going wrong and where to get parts. Im also going to be in the market for a set of ski's and decals for the sled.
Thanks,
Dan
Worley91 is offline   Reply With Quote
Old 12-23-2008, 12:11 AM   #63 (permalink)
noobie
Any updates?This has been a good read!
noobie is offline   Reply With Quote
Old 08-22-2009, 02:21 AM   #64 (permalink)
nckruddy
I have the same sled. I got it to run once. Then it backfired out the air intake and will not start again. Any ideas? Also the carb is not filling with gas. It will run on starting fluid then when it burns off its done. The carb on it is not original, could you tell me what carb and the numbers are on this one? Id love a replacement. If I could fine one. Also any ideas on how to get it to run would be greatly appreciated.
nckruddy is offline   Reply With Quote
Old 08-22-2009, 08:38 AM   #65 (permalink)
Wahlbro HR carb most likely.
Needs to be taken apart and cleaned thoroughly as the diaphragm and gaskets have deteriorated and the jets are probably clogged with varnish.
Old 08-22-2009, 05:44 PM   #66 (permalink)
nckruddy
I replaced all the gaskets and guts. Anywhere I can get just na new carb? I cant even get it to fill the bowl with gas. Tried adjusting the float. Its set fine and not stuck.
Old 08-22-2009, 07:03 PM   #67 (permalink)
Got pics?
Old 08-22-2009, 11:57 PM   #68 (permalink)
nckruddy
I can get some. You want motor or random ones in general of the sled?
Old 08-23-2009, 08:44 AM   #69 (permalink)
Motor + carbs.
Old 08-23-2009, 10:51 AM   #70 (permalink)
nckruddy
Heres a few pics for you. Let me know if you need anymore. I thought the fuel lines are on wrong since it doesnt pump. Let me know what you think. Also someone added a choke when there is a primer already
79-scorpion-whip-440-questions-sled-001.jpg  79-scorpion-whip-440-questions-sled-002.jpg  79-scorpion-whip-440-questions-sled-003.jpg  79-scorpion-whip-440-questions-sled-004.jpg  79-scorpion-whip-440-questions-sled-005.jpg
Old 08-23-2009, 10:51 AM   #71 (permalink)
nckruddy
One more for you to look at
Old 08-23-2009, 01:16 PM   #72 (permalink)
nckruddy
I had it running one winter. I drove it around my yard and up and down my driveway then a large pop from the air intake partial melting the intake. I havent got it to run that good again.
Old 08-23-2009, 07:00 PM   #73 (permalink)
nckruddy
This is a little whip 300 sorry I was off
