2004 factory mod sled. Sled runs great, and is a blast to ride! but must go! Speedwerx built 600cc motor using oem f6 top end on a f7 bottom end for durability, Cylinders are ported, head is reconfigured for pump gas currently but 114 octane speedwerx sleeper head is also available for an extra $100, and full twin pipes were modified to run with this set up(by Speedwerx). Team secondary. Digitron, water temp guage, Fox Zero-X front shocks.C&A pro skis w/woodys square bars. Cross link rear skid. 3.0 pitch attack 20 track w/extrovert drivers.No torn or damaged lugs. Studs are all in good shape. CanvasWorks seat cover. No rips or tears. Sled is converted for trail use, has extra gas carrying capacity on the rear rack as you can see, cdi was reprogrammed and extra coolers were installed, headlights installed, premix only, the hood isnt a factory hood for this sled, so the pipes have melted two holes in it but still works fine. This is could be converted easily back to race only or is ready to tear up the trails as is! asking 3100 obo. located in ames, iowa. SERIOUS INQUIRES ONLY!!! email at
skibum_1260@hotmail.com or call at 515-298-0951 for questions as i dont check this site.
