Been there... Disconnect both lines, and remove the pump. Get a battery and hook up the pump. Take a gas line and connect it to the pump and put it in water. Hook up the battery and see if it pumps. It should push a great amount of water through. If not, I bet the pump is plugged somewhere... Let it run a little longer.
