1998 Arctic Cat ZR 600 EFI parts
Decided to try this route instead of paying EBay/Paypal fees again. I have a few parts off of a 1998 ZR 600 EFI that I can't use or do not need as extras...mostly electrical, front suspension and drive related. I don't have any rear suspension, motor, track, or body parts/panels.
Here's a quick list of what I do have...
Complete front suspension: all A-arms, shocks, spindles, tie-rods-no skis
Complete steering: steering post, pivots, etc-no handlebars
Driveshaft-9 lug/cog-will include speedo side or can seperate if wanted
Oil/coolant reservoir with low oil sensor-coolant overflow nub is broke off-shouldn't be a big deal
Complete rear heat exchangers with rubber hose between them-great cond.
Jackshaft (driven clutch to chain case) with bearings, brake rotor, and clutch side motor mount-can seperate if needed
Chaincase with all parts minus large gear-I'd like to keep the top 20T gear myself too but everything else is complete (bearings, nuts/bolts, chain, etc.)
Air Silencer Plenum (bottom of airbox)
Voltage regulator
Throttle Body cables-from main throttle to throttle bodies and oil pump
Main engine harness-from motor to tail light to volt. reg to ign coil, etc.
Email with what you're interested in. This stuff needs to go so I have some more room around here. I'm pretty flexible with what I want to get out of these parts except on the front suspension. I'd like around $150 for everything, shocks/a-arms/spindles.
If you're interested in the rear of the tunnel for a longtrack conversion, let me know. I chopped the back off of it since it was square and thought I could use it but now have a mountain sled and don't need it.
Wife has camera at work so let me know if you need/want a picture of something and I'll try to take one when I get a chance.
Nubby
