Homemade Trailer Build - Snowmobile Forum: Your #1 Snowmobile Forum
post #1 of 4 (permalink) Old 11-17-2016, 03:35 PM Thread Starter
I am building a 12ft drive off/on trailer.
Galvanized. This trailer is all bolted, no welding required.
All bolts will be either 1/2" dia or 3/8" dia. See images.
I am asking for advise on my steel member sizes? I think they are adequate enough, just wondering about if anybody has built their own.
Deck will be 2x6 lumber.
Thanks!
Name:	side views.jpg
ID:	55162   Click image for larger version
ID:	55170   Click image for larger version
2004 Polaris 600 Pro X2
1980 Arctic Cat El Tigre 6000
Kirk36 is offline
post #2 of 4 (permalink) Old 11-17-2016, 09:38 PM
Quoted: 91 Post(s)
A 2x6 deck will be really heavy. Most single axle trailers with axle/wheels under the deck use 3/4" marine grade plywood.
Make sure your axle and tires/wheels can take the weight of two sleds plus the weight of the wood. You don't want to have an axle that is not rated for the load.
Good luck with the project!
BC_Dan is offline
post #3 of 4 (permalink) Old 11-18-2016, 04:45 AM
A trailer that length will handle better with two axles and have more load capacity as well.
As Dan mentioned, be sure to use an axle that can handle the load {2000lb+} and that it is located far enough back to have proper tongue weight or it will wander all over and be dangerous to tow.
post #4 of 4 (permalink) Old 11-18-2016, 08:51 AM Thread Starter
Thanks for the comments!
Marine grade 3/4 plywood is 52# per 4x8 sheet, and I would need 4 sheets with some cut off, this is around 208#. 2x6 lumber is 2# per foot, and I have 426# of lumber, so yeah the lumber is twice heavier. I like the idea using the 2x6 lumber, so I can just replace a board if it gets damaged.
I have 1,247# total weight just the trailer. Add in another 1,000# for (2) sleds and I am at 2,247#.
I think I will use (1) 3500# torsion axle, or I could use (2) 2200# axles, that should handle the weight.
It looks like the torsion axles come in different "start angles" 22 degrees, 30 degrees, 45 degrees and 0 degrees? Any ideas on these start angles? Is the start angle how high the trailer will be with no load? Just wondering and concerned if I use a 22 degree start angle, and the wheel hits the trailer when I load the sleds?
Kirk36 is offline
