Originally posted by MackmxzX
here is the one i made...i just took the pic so its not that clear...i welded a 5 ft square tubing and a 3ft wide square tubing and bolted the fence to it...i used rope from each corner and a beaner clip...if i was to do it again i would make it a tad smaller... maybe a 3x3 instead..it would work just as well
Nice! I bet you could tie-wrap the fence to it, rather than bolting it on. Probably be a bit easier to fasten. Still, that's a nice drag.
Does it put a lot of strain on the pulling sled? I wouldn't think it would be too bad...
2000 440 Panther
1980 Jag 3000 F/C
Member:
Canaltown Snowmobilers Inc.
