Go Back   Snowmobile Forum: Your #1 Snowmobile Forum > General Discussion Forums > Trail Riding
Old 11-21-2007, 11:43 PM   #1 (permalink)
jKsled
Sconnie
jKsled's Avatar
suspension settings
what are the best suspension settings for general trail riding? on my '85 formula mx, there are two springs/shocks in the rear and one in the front of the rear suspension. they have five adjustements on them. i weigh about 205-210 also. I'm looking for something with better steering at both low and high speeds. acceleration is not main concern, just felt that it was too difficult to steer when i took it out tonight. thanks
~If you dont think it's bad @zz, then whats the point?~
1990 Skidoo Formula MX 470
1986 Ford Ranger 2.9L 4x4
3"body lift
3" Skyjacker suspension lift
dual custom exhaust
Old 11-22-2007, 07:50 AM   #2 (permalink)
Adjust the suspension so it doesn't bottom over large bumps. Adjusting the rubber limiter strap at the front ofthe rear suspension adjusts weight on the skis.
Old 11-22-2007, 08:36 AM   #3 (permalink)
jKsled
Sconnie
jKsled's Avatar
do i tighten it then to put more weight on skis?
3"body lift
dual custom exhaust
Old 11-22-2007, 09:48 AM   #4 (permalink)
Yes, tighten or shorten to shift more down pressure to the skis.
Was it "pushing or scuffing" in the turns or very hard to turn (requiring a lot of effort)?
Old 11-22-2007, 10:50 AM   #5 (permalink)
jKsled
Sconnie
jKsled's Avatar
it was definitaly pushing around the corners. i don't have carbides, just wear bars. it was hard to hold it at a full turn, but thats just becasue it was pushing i think.
3"body lift
dual custom exhaust
Old 11-22-2007, 10:54 AM   #6 (permalink)
First thing then is check the condition of the bars. If they are worn, the sled will not turn.
Carbides are actually cheaper in the long run as they last longer.
If you have any studs in the track, you should be using a carbide of at least 6".
Try this first, if it solves the problem, you do not need to do more. If not, then you need to make adjustments to the suspension.
Old 11-22-2007, 11:21 AM   #7 (permalink)
jKsled
Sconnie
jKsled's Avatar
no studs, and wear bar isn't that worn, but as of right now i can't afford new carbides along with all the other stuff. so im thinking adjustments would be best
3"body lift
dual custom exhaust
Old 11-23-2007, 12:33 AM   #8 (permalink)
I'm not sure on the 'Doo, but most sleds have at least 2 mounting holes for the upper skid mounts.
If so, move the rear arm to the lower hole of the tunnel mount. this will shift more weight onto the skis. If there is not another lower hole, you will either have to shorten the front limiter a little or start by letting a little of the pre-load off the front shock/spring.
Old 12-27-2007, 11:01 AM   #9 (permalink)
Jaded
Jaded
Jaded's Avatar
Shorten the rubber limiter strap/s as SEG mentioned and also check your ski alignment
Jaded is offline   Reply With Quote
Old 12-27-2007, 08:51 PM   #10 (permalink)
Jim Jessup
Hiberna Somnium
Jim Jessup's Avatar
I believe on that susension, the limiter is controled by tightening or loosening a nut on the bottom of the front arm. Same idea though, just a different method.
The fleet...
1989 Ski-Doo Formula Mach 1
1996 Yamaha Vmax-4
1997 Ski-Doo Mach 1
1998 Yamaha Venture
1999 Ski-Doo Formula S
Jim Jessup is offline   Reply With Quote
