Go Back   Snowmobile Forum: Your #1 Snowmobile Forum > Picture Gallery > Snowmobile Still Shots
Old 10-08-2007, 01:48 PM   #21 (permalink)
Jim Jessup
Hiberna Somnium
Jim Jessup's Avatar
I know what you mean Iceman. Sometimes I wish I could get a set of pipes for my vintage sleds but most of them would have to be custom made. I just got a FAST can for the Mach so hopefully it will sound even better than it does now. It also comes with the pipe but its not for the 521, so next year I might re-build the 583 and drop it back in.
The fleet...
1989 Ski-Doo Formula Mach 1
1996 Yamaha Vmax-4
1997 Ski-Doo Mach 1
1998 Yamaha Venture
1999 Ski-Doo Formula S
Jim Jessup is offline   Reply With Quote
Old 10-17-2007, 07:36 PM   #22 (permalink)
iceman400
iceman400's Avatar
oh cool... if you dont mind me askin how much did that set you bac? where did you get it from? any carb mods?
Connor.
1992 Formula PlusX 617
1993 Formula Plus 580
YEA GOTTA LOVE THE PRS!
1996 Jeep grand cherokee Limited
1966 Dodge Charger-BAD ASS
iceman400 is offline   Reply With Quote
Old 10-17-2007, 08:24 PM   #23 (permalink)
Jim Jessup
Hiberna Somnium
Jim Jessup's Avatar
I bought it used from the U.S for $50.00+ shipping. I don't think I need to make any jetting changes since I'm only using the can for now, since the pipe isn't for a 521. At least thats what I've read. I've done alot of research, and so far I havn't found any companys still making new off the shelf pipes for the PRS. I had been keeping an eye for a set for awhile.
The fleet...
1996 Yamaha Vmax-4
1997 Ski-Doo Mach 1
1998 Yamaha Venture
Old 10-18-2007, 08:02 PM   #24 (permalink)
radianguy
radianguy's Avatar
Awesome job, that looks great!
First ever SOTM winner Dec 2005
2003 Polaris 600 SKS
radianguy is offline   Reply With Quote
Old 04-06-2008, 06:42 PM   #25 (permalink)
Jim Jessup
Hiberna Somnium
Jim Jessup's Avatar
Well back to square one.
The fleet...
1996 Yamaha Vmax-4
1997 Ski-Doo Mach 1
1998 Yamaha Venture
Old 04-27-2008, 10:41 AM   #26 (permalink)
Jim Jessup
Hiberna Somnium
Jim Jessup's Avatar
Well, I've been working away at the Mach and have the new front suspension intalled to see how it would fit and if it needed any adjustments. The parts are off a newer PRS so the ski stance will be around 40" now. I also installed the twin pipes to see how they would fit. Soon the frame will be going out for some welding and to get sand blasted.
The fleet...
1996 Yamaha Vmax-4
1997 Ski-Doo Mach 1
1998 Yamaha Venture
Old 04-27-2008, 05:00 PM   #27 (permalink)
iceman400
iceman400's Avatar
Looking good!.. when we had a triple in our 92 plusX the part of the frame where the front shock tower mounts too had to be cut out and re-welded for the triple pipes to fit... and you will like the bit wider stance, it makes a big difference when high speed cornering.
Old 04-28-2008, 04:07 AM   #28 (permalink)
Dyno Port - Aftermarket Pipes, Silencers, Porting, Clutching, and More! - www.dynoport.com
Dyno Port - Aftermarket Pipes, Silencers, Porting, Clutching, and More! - Dyno Port - Aftermarket Pipes, Silencers, Porting, Clutching, and More! - www.dynoport.com
Try here for pipes made for your engine.
Old 04-28-2008, 06:19 AM   #29 (permalink)
Hey, Jim, what's the newer suspension out of?
Old 04-28-2008, 03:57 PM   #30 (permalink)
Jim Jessup
Hiberna Somnium
Jim Jessup's Avatar
RJ, I already have a set of pipes for my engine. They are DG pipes and came off an 88 Formula plus with the type 537, 521. Fit is perfect, only thing I noticed is that the one pipe is in the way of the hood cable.
SEG, parts came off a 93 Plus EFI. Includes upper and lower radius rods, tie rods, sway bar, and steering arms.
The fleet...
1996 Yamaha Vmax-4
1997 Ski-Doo Mach 1
1998 Yamaha Venture
Old 04-28-2008, 06:22 PM   #31 (permalink)
Gotcha, same as my Mach 1. Time to put an SC-10 under the back of that bad boy!
Old 04-30-2008, 04:01 PM   #32 (permalink)
Jim Jessup
Hiberna Somnium
Jim Jessup's Avatar
Compared to the 36" stance it had before the 40" will be perfect. I never really noticed the difference until we loaded it on the trailer and both skis went between the ski guides. After that I knew I had to go to a wider stance.
SC-10 is part of the summer project, still looking for one for a decent price. Problem is I don't know what to measure. Eg; do I measure from the drivers to the front of the rails?
The fleet...
1996 Yamaha Vmax-4
1997 Ski-Doo Mach 1
1998 Yamaha Venture
Old 05-01-2008, 06:26 AM   #33 (permalink)
CHeck out the thread I posted of how I installed mine.
http://www.snowmobileforum.com/gener...ork-begin.html
Old 05-28-2008, 07:06 PM   #34 (permalink)
Jim Jessup
Hiberna Somnium
Jim Jessup's Avatar
Thanks for the link SEG and sorry for the slow response.
Since posting these last pictures I've gotton a set of handle bars off a Formula S(my sister's machine for now), a chaincase off a 97 Mach Z, and a hydraulic brake system off a 98 Mach Z.
The purpose of getting the newer bars is to get rid of the narrow ape hanger bars that the PRS Doo's came with. I'm going to have to section the upper neck of the steering column or use a bar riser on the bar mounts to bring the bars up higher. This will allow me to use the bar pad off the Formula to give it a clean look and to make it look factory.
The fleet...
1996 Yamaha Vmax-4
1997 Ski-Doo Mach 1
1998 Yamaha Venture
Old 05-29-2008, 05:45 AM   #35 (permalink)
Nice! Did the hydraulic brake bolt right up?
Old 05-29-2008, 03:28 PM   #36 (permalink)
Jim Jessup
Hiberna Somnium
Jim Jessup's Avatar
I'm not sure if it will bolt up or not. The caliper will bolt to the chaincase no problem, the only thing I could see being a problem is the rotor or the clearance from the oil tank support.
So far I've only gotton the chaincase and handle bars bolted up. I need to move the counter shaft over a bit but that won't be a problem. I won't have time to get the brakes hooked up for a couple weeks because I'm pulling everything back off again to separate the bulkhead from the tunnel.
The fleet...
1996 Yamaha Vmax-4
1997 Ski-Doo Mach 1
1998 Yamaha Venture
Old 05-29-2008, 08:24 PM   #37 (permalink)
Let me know how you make out. I'd love to put hydraulics on my Mach 1.
Old 05-30-2008, 08:02 PM   #38 (permalink)
Jim Jessup
Hiberna Somnium
Jim Jessup's Avatar
No problem. I'm really hoping it will bolt up.
The fleet...
1996 Yamaha Vmax-4
1997 Ski-Doo Mach 1
1998 Yamaha Venture
Old 06-10-2008, 05:19 PM   #39 (permalink)
Jim Jessup
Hiberna Somnium
Jim Jessup's Avatar
SEG, I decided to hold off on pulling the frame apart and installed the chaincase, countershaft, rotor and drive shaft. I then installed the oil tank support. Everything bolted up to the chaincase, but I'm also running a newer axle. This allows me to use the newer chaincase cover. The caliper was next, bolted right up and the rotor had enough play side to side to center between the brake pads. The diameter of the rotor is also right. As far as I can tell everything else should bolt up and not get in the way. Might have to do something with the starting rope...maybe.
I'm going to get some pictures tonight and post them.
The fleet...
1996 Yamaha Vmax-4
1997 Ski-Doo Mach 1
1998 Yamaha Venture
Old 06-10-2008, 09:26 PM   #40 (permalink)
Nice, thanks!
