Old 01-22-2003, 01:26 PM   #1 (permalink)
tomk_22
ski doo melting pistons
i have a 91 formula plus 521cc , oversized .020 it keeps melting the top tof the piston what is the problem? how do i set the timing and what are the proper jets to use.
tomk_22 is offline   Reply With Quote
Old 01-27-2003, 10:14 PM   #2 (permalink)
finn
Check for air leaks.....pluged jets....sounds lean
finn is offline   Reply With Quote
Old 02-07-2003, 12:24 PM   #3 (permalink)
dano
I agree, sounds like your jetting is way off. To lean, less air, more fuel.
dano is offline   Reply With Quote
Old 04-23-2003, 07:02 PM   #4 (permalink)
Garganos
I agree about the jetting. I would also pressure test your engine and check for any seal leaks. To set you timing you need to rotate your stator under the flywheel. You also new a Strobotic Timing Light. A Std. timing light wont work because it won't keep up with the freqeuncy of a 2 stroke. What kind of pistons. If there not Rotax ie Wiesco (seizeco) then you would need to increase your piston to cylinder wall clearance due to lessened silicone content.
GOOD LUCK
Gargano's
Sea-doo, Ski-doo & Arctic Cat
Garganos is offline   Reply With Quote
