97 SkiDoo Formula 583 Volt Reg Replacement with Kimpex - Snowmobile Forum: Your #1 Snowmobile Forum
post #1 of 11 (permalink) Old 12-30-2013, 11:32 AM Thread Starter
I've been having issues on my 97 Formula 583 in that the rear tail light is always on and brake light on dash when started and idling ... when I rev it up the tail light blows as does the low beam. I believe it to be the voltage regulator and replaced it with a Kimpex 01-154-15 but problem persists. The 2 wires off the Kimpex are one is black the other yellow whereas the original ski-doo on was YL and YL/BK. I couldn't find any instructions on how to wire up so thought it to be BL to YL/BL and YL to YL... does that sound correct? I'm gonna measure the AC out tonight but if not the regulator what else could be my problem?
amaahs is offline
post #2 of 11 (permalink) Old 12-30-2013, 04:26 PM
Do the other lights blow? If not, the problem lies in the taillight/brakelight circuit.
2009 Ski Doo MXZ 500SS TnT
1999 Ski Doo MXZ600
smallengineguy is offline
post #3 of 11 (permalink) Old 12-30-2013, 06:15 PM Thread Starter
Yep low beam front light blows as well
amaahs is offline
post #4 of 11 (permalink) Old 12-30-2013, 09:11 PM
Not correct on the hook up. YL/BL feeds the rect. Y feeds the lighting circuit if that makes sense. Black is the ground. Probably not the correct regulator.
ken3296 is offline
post #5 of 11 (permalink) Old 12-30-2013, 11:25 PM
aduck's Avatar
Quoted: 13 Post(s)
My guess is the harness under the seat is,chaffed.
93 mach1 670
02 rmk 800 162
95 powder special 580
aduck is offline
post #6 of 11 (permalink) Old 12-31-2013, 05:34 AM
TheBearAk's Avatar
Quoted: 54 Post(s)
According to Kimpex, that is the correct regulator. My concern is that there is only 2 wires. typically Kimpex have two yellow and a black. Ones that charge battery may have a green/yellow.
Black is usually grounded to the frame. In fact, if you do a continuity test between the black and the case, it will zero ohms, dead short. The black wire is in case you cannot mount it to a bare metal part of the frame.
TheBearAk is offline
post #7 of 11 (permalink) Old 12-31-2013, 12:20 PM Thread Starter
I measured ac at regulator and stays around 12v ... I noticed now the oil light is also on... Disconnected the regulator and all conditions remain the same... Gonna take a good look at the wiring
amaahs is offline
post #8 of 11 (permalink) Old 01-01-2014, 05:47 PM Thread Starter
Cleaned up some wiring that had frayed... Put back original regulator and tested.. Stays at 12 .. 13 volts but brake light stays on.. Electrical brake cable is loose and comes off easy at brake lever ... Keeping at it
amaahs is offline
post #9 of 11 (permalink) Old 01-02-2014, 06:38 AM
TheBearAk's Avatar
Quoted: 54 Post(s)
I read in another forum that people who wired this regulator found there was a feed back through the ground that keeps the indicators lights on. One guy put a diode in there and solved his issue, but I'm just not confident with it.
I suppose it just depends on how the stator is wired. If it a 2 phase stator, then ground is a common (like the white wire in house 240 Volt circuit). My understanding is most are not and they actually have two separate coil windings and that the ignition circuit uses engine/frame ground and accessory does not use a ground, but rather much like a house 240 volt, it has two "hots".
post #10 of 11 (permalink) Old 01-02-2014, 08:41 AM Thread Starter
yesterday after cleaning up the frayed wiring and I put back the original Ski-Doo regulator and measured the AC it stayed around 12v even after reving but problem persisted ... I took a closer look at the Hydraulic brake power cable referred to as a microswitch and the cable was loose and appears broke off in the brake lever so this maybe my problem all along... will look to buy a replacement
amaahs is offline
post #11 of 11 (permalink) Old 01-04-2014, 01:16 PM Thread Starter
I replaced the microswitch as it had snapped off... brake light now works as it should and I'm not blowing bulbs... not sure if that fixed it or when I went thru and cleaned up some wiring that had the insulation burnt off it... so that has been fixed but now got more problems... I guess that's what ya get for getting an older used sled
amaahs is offline
