YOU ARE GOING TO HAVE A HARD TIME FINDING ANYTHING BUT USED PIPES DUE TO THE YEAR OF THE SLED, DO A LITTLE CARB WORK,AND MAYBE CHANGE ROTARY VALVE(AVAILABLE THROUGH DENNIS KIRK) AND FORGET THE PIPE IT WILL RUN JUST FINE, WITH A PIPE COMES CLUTCHING AND OTHER CHANGES. A WELL TUNED 583 WILL RUN REAL GOOD STOCK
GOOD LUCK!
