speed formula 500? - Snowmobile Forum: Your #1 Snowmobile Forum
post #1 of 9 (permalink) Old 08-29-2005, 10:02 PM Thread Starter
Arctic Cat Man
njk4o5's Avatar
speed formula 500?
how fast shuld a bone stock 96' skidoo formula sl 500 go with 3400 miles? a local mechanic said it suld go about 90 but it only goes 60. when i hav it up there it randomly ticks but when it does its LOUD. the carbs are clean and it runs great at lower speeds except it picks up pretty slow but i think thats is because its old. wat could be holding it back??
how often should the hyfax be replaced?
and will any modern rear suspensions fit this sled??
thanx for any help
njk4o5 is offline
post #2 of 9 (permalink) Old 08-31-2005, 05:52 PM
skidoorider's Avatar
i have a 1987 ski-doo saffari. its a 377 and is all stock. it has really good take off and i can get it up to about 60mph. my mom said when she first got it it could do like 70. and it has around 4,000 miles on it.
skidoorider is offline
post #3 of 9 (permalink) Old 09-01-2005, 01:23 PM
Water Runner
SledStormIanAmy's Avatar
Your pistons and rings might be worn out. You might want to rebuild your motor. Depending on snow condidtions, you may get 10,000 miles on a set of hyfax, or a few miles. Even so, you should replace them at least once a year. And concerning a suspension upgrade, I think the FAST M-10 would fit in your sled.
!997 Polaris Storm 800
3" Riser
Handlebar Hooks
1.5" Lug Track
SledStormIanAmy is offline
post #4 of 9 (permalink) Old 09-01-2005, 03:50 PM Thread Starter
Arctic Cat Man
njk4o5's Avatar
it has great compression so i dont think it could be the pistons/rings. could it be the clutches or driver wheels?? this sled has to hav more speed cuz my moms 01' 380 can beat it.
njk4o5 is offline
post #5 of 9 (permalink) Old 09-02-2005, 06:41 AM
Take it across a lake or something wide open, then immediately shut it down. Check to see what the spark plugs look like. If they are a whitish color, it's running too lean on top end. You can change the main jets larger if so. By what you're describing, it's starving for fuel on top end, or the clutches aren't operating all the way.
2009 Ski Doo MXZ 500SS TnT
1999 Ski Doo MXZ600
smallengineguy is offline
post #6 of 9 (permalink) Old 09-12-2005, 11:22 AM
Winter Fanatic
MackmxzX's Avatar
have you ever blown a belt? sometimes the shaving and little ropes that hold it together get rapped on the clutch driver and lock up the bearings or washer and create friction which might make the ticking and bring down the speed....good luck
MackmxzX is offline
post #7 of 9 (permalink) Old 09-12-2005, 04:25 PM
Go Wings!
skidoo_magoo's Avatar
had my 97 500 formula de-luxe up to 95ish (speedo).
skidoo_magoo is offline
post #8 of 9 (permalink) Old 09-12-2005, 05:04 PM
Winter Fanatic
MackmxzX's Avatar
thats awesome for a 500 deluxe i think!
MackmxzX is offline
post #9 of 9 (permalink) Old 09-12-2005, 05:48 PM
Go Wings!
...it is bored out a bit
