Old 11-22-2003, 01:41 PM   #1 (permalink)
Ed Rapp
86 safari
Picked up used 86 safari. Don't have manual yet. Drive gear box has plug rather than dip stick. How full do I fill and with what type oil? Thanks Ed
rivetgun55
Ed Rapp is offline   Reply With Quote
Old 11-22-2003, 02:44 PM   #2 (permalink)
Fendrguy
Where's the snow?
Fendrguy's Avatar
is there a # stamp on the cast?
call the skidoo dealer and ask them how much to put in.
I use MAXIMA chain case lube, its about 5 bucks a 16OZ bottle.
Fendrguy is offline   Reply With Quote
Old 11-22-2003, 03:32 PM   #3 (permalink)
01MXZ800
01MXZ800's Avatar
HAVE YOU PULLED THE PLUG? MY '89 HAD A DIP STICK ATTACHED TO PLUG,IF NOT ABOUT A PINT SHOULD BE RIGHT
GOOD LUCK
01 MXZ 800
Old Erie Riders Snowmobile Club
Lake Shore Snow devils Snowmobile Club
Old 11-22-2003, 05:57 PM   #4 (permalink)
Ed Rapp
Mine just has a plug with no dip stick. That why I didnt know to what level to fill it to. Thanks!
rivetgun55
Old 11-25-2003, 11:14 PM   #5 (permalink)
dl_sledding
Is there another plug on the side cover of the chaincase, lower than the fill tube? If memory serves, some of the sleds had a plug that you pulled out, filled thru the fill tube until the lube started running out of the plug hole. Replace the plug again after filling, of course
dl_sledding is offline   Reply With Quote
Old 12-08-2003, 11:02 PM   #6 (permalink)
bbarry2k
chaincase oil
Factory manual says 7 fl oz
bbarry2k is offline   Reply With Quote
Old 03-27-2004, 05:59 AM   #7 (permalink)
I check my case every 300 mi or so. It only takes a second, and it let me know my shaft seal was leaking last year! I use Klotz synthetic, much less wear!
