» Site Navigation
» Power Sports Links
Old 11-20-2003, 06:58 PM   #1 (permalink)
2000 mxz 600
I have 2 questions...
1) Are reed valves worth the money and are the performance gains noticeable on a 600?
2) I am having a tough time getting my suspension adjusted properly. The back end of the sled is extremely loose. It is particularly bad when letting off of the throttle..I've tried taking pressure off the front skis as it feels like there is too much ski pressure. This didn't seem to help much. Any suggestions on what adjustment to make to help solve this problem?
kov38 is offline   Reply With Quote
Old 11-28-2003, 07:05 PM   #2 (permalink)
Reeds will increase your throttle response. V-Force reeds are probally the best concept in reed designs (the new 600HO & 800HO utilize this style).
Where are your coupling blocks set. You may want to try uncoupling the rear suspension. Also, try lenghting your limiter strap. This will give you more ski lift. If that works but you still want more ski lift you can try increasing your spring tension on the center shock (front of rear suspension)
Gargano's
Sea-doo, Ski-doo & Arctic Cat
Garganos is offline   Reply With Quote
