'97 Summit - LOTS of oil in pipe... - Snowmobile Forum: Your #1 Snowmobile Forum
Old 01-24-2013, 01:54 PM   #1 (permalink)
rgoers's Avatar
I seem to remember something similar last season, but I wish I knew WHY. Seems the first few times I run the Doo, it smokes like crazy. Then, when I park it, I come out the next day to a two foot diameter puddle of oil on the garage floor.
Assuming I have the oiler set properly (it doesn't smoke the rest of the season, and uses oil at a rate consistent with a 50:1 ratio), how is THAT much oil getting into the pipe?
2004 Polaris Trail RMK 136
1997 Ski Doo Summit 500
Old 01-24-2013, 05:30 PM   #2 (permalink)
Replace the pump. The seal may be gone, allowing oil to get into the engine. Pumps are cheap.
Old 01-24-2013, 10:51 PM   #3 (permalink)
rgoers's Avatar
Couldn't I just replace the seal then? Looks like pump would run about $40 or so... used, on eBay.
Old 01-25-2013, 03:38 AM   #4 (permalink)
Not sure if the pump seals are servicable. Check www.hlsm.com and see if the ycan be replaced.
Old 01-25-2013, 12:13 PM   #5 (permalink)
Re: '97 Summit - LOTS of oil in pipe...
I have a 1999 formula deluxe 670 with the same problem. My dealer says it is the oil seal on the rotary valve shaft.
Sent from my SPH-L710 using Snowmobile.com App
gary_warner4 is offline   Reply With Quote
