I have a 1999 MX-Z 670.
Does anyone know if it is OK that the outer clutch plate can be turned manually, but the engine doesn't?
I am afraid that the clutch is going to fail when I am out riding or something.
The reason I noticed this is because my recoil broke a few weekends ago and I tried the manual starting procedure of winding the rope around the clutch.
But the engine was not turned over when I did it.
The outer clutch part turned, but the engine did not rotate.
If you can see the picture I attached, I can turn the piece with the arrow on it, but the black HUB with the square on it stays still (so does the motor)
I asked this in my other post, but I think this topic got buried. So please excuse if it seems duplicate.
