95 formula sl 500 fan
Guy I have a 95 formula sl fan runs awesome. The other day it was -36 so I put some gas line anti freeze in the feul. Fouled a plug replace plug and ran fin for a day. Know at low rpm it floods the pto side cylinder and boots down. But as soon as I get me rpm up it runs off both cylinders. Tried everything I can get it to run good at idle but onLy if I remove that side throttle plug from the carb. Then it idles like it should.can anyone explain why and give me some ideas to fix it. Maybe the plug is not seating propErly but why does it run when fuly removed.
Thanks guys
