01-13-2013, 01:28 PM
I'm back problems with the doo
Well yesterday I went out and put about 80 miles on. On the way back to my house about 5 blocks away the belt started slipping I just went through a drift in the alley so I figured snow got on the belt somehow so I cautiously rode home and parked it. Cracked open the hood and belt guard to find a oily mixture with belt grindings in it it was built up mostly towards the middle of the sled any ideas? Can post pics if needed....
01-13-2013, 07:09 PM
pics please.
01-13-2013, 08:16 PM
01-13-2013, 08:45 PM
crank seal behind primary leaking?Did it run different at any point,high rpm,bog on acceleration?
01-14-2013, 04:54 AM
Certainly looks as if the crank seal is leaking outward at this point.
Time to replace it.
01-14-2013, 06:26 AM
Get a clutch puller, remove the clutch and replace the seal. Don't even have to remove the engine.
1999 Ski Doo Grand Touring
01-14-2013, 07:13 AM
I'll order one later today is it pretty easy to replace?
01-15-2013, 06:14 AM
Very. Use a screwdriver to pull the old one out, then find a socket the same diameter as the outer part of the seal. Pop it in!
01-15-2013, 11:36 AM
After some extreme wrestling with the sled I got it flipped on its side clutched popped off using the water trick and I can't get the clutch all the way off because the side or belly is blocking it any ideas and thanks for all the help
01-18-2013, 07:15 AM
Got clutch off went out to work on it last night and it came right off how Exactly do I get the seal out with out stabbing it with a screw driver?
01-18-2013, 11:26 AM
Use the screwdriver to pry the old seal out.
Also don't forget to put some grease on the lip when you install the seal so that it slide onto the shaft easier.
