Testing Voltage - Snowmobile Forum: Your #1 Snowmobile Forum
Old 01-10-2013, 02:54 PM   #1 (permalink)
zilla600's Avatar
Testing Voltage
What is the best way to test the voltage on a 91 Ski Doo Safari 377. I want to confirm that the voltage regulator is not working properly before I replace it. It blew a brand new bulb the last time I started it... No need to hurry on the response, its going to be 51 tomorrow with rain and 58 on Saturday. Not even sure why I'm bothering with it now!.
1989 Yamaha Exciter My Sled
1985 Yamaha XLV Wifes Sled
1977 Arctic Cat Kitty Kat Sons Sled
zilla600 is offline   Reply With Quote
Old 01-10-2013, 06:10 PM   #2 (permalink)
There should be 30-40 VAC coming out of the motor into the regulator, and no more than about 13VDC or so out of the regulator.
1999 Ski Doo Grand Touring
Old 01-11-2013, 08:42 AM   #3 (permalink)
zilla600's Avatar
Thanks SEG! Just a couple more questions.
1. Can I test the voltage output at the light socket or the battery leads?
2. Should the motor be reving up to test voltage, or should it be tested at idle?
Thanks to All!
Old 01-11-2013, 01:36 PM   #4 (permalink)
Both, at idle you would get around 12.5vac and past 1/3 throttle [3000 rpm] you would be about 28vac before the regulator and at wot, as much as 40vac.
at the battery, you should never get more than 14.5vdc and a minimum of 12.5vdc.
