It should fit fairly snug, and yes, there should be two bushings, one on each end. It's designed so the bushings wear, not the bracket. The bushings should fit into the hole in the bracket and the bolt should then slide through. When everything is tightened down the ski should pivot up an down with little to no movement side to side. If your bushings are worn or missing you should be able to find replacements at your local hardware store.
