lets see who can figue this one out - Snowmobile Forum: Your #1 Snowmobile Forum
Old 12-29-2012, 03:01 PM   #1 (permalink)
so i have tried everything on my old citation and still nothoing if anybody can help please to do a quick run down of what i have done changed points and condensers set timing drained old gas and put new in new and correct plugs the only thing i have left to do is check the compression which i will do monday as thats when i get my compression tester but i checked the compression the old way and it blew my finger off so i do not know what else to do oh and i took apart the carb and cleaned it all out so pleaseeeeeeeeeeee any input would be great
33rubenanthonty is offline   Reply With Quote
Old 12-29-2012, 03:38 PM   #2 (permalink)
Live to ride
99Polaris500's Avatar
Is gas getting to the carb?
'99 Polaris xc 500
'91 Arctic Cat prowler 440
99Polaris500 is offline   Reply With Quote
Old 12-29-2012, 03:54 PM   #3 (permalink)
Ultrafrozen's Avatar
Do you have spark at the spark plug(s).
When you did the carb(s) did you clean out the jets?
Gallery Pictures.
Current Sleds: A few
Old 12-29-2012, 03:59 PM   #4 (permalink)
yes when i opened the bhe bottom nut of the carb there was gas that came out the fuel punp is working fine i actially took that aprt and cleaned it all out as well
Old 12-29-2012, 04:02 PM   #5 (permalink)
yes the spark plug are getting spark and i actually replaced the jets when i cleaned out the carb
Old 12-29-2012, 06:03 PM   #6 (permalink)
Live to ride
Are the plugs wet after you try to start it? Make sure the carb boots are on good, and no excess air is getting in.
'99 Polaris xc 500
Old 12-29-2012, 07:10 PM   #7 (permalink)
hmmm.....yes i would say the spark is wet but not crazy wet and the carb boot is on there perfect and itis brand new but shouldnt the spark plug be a little wet
