Mxz 700 Idle - Snowmobile Forum: Your #1 Snowmobile Forum
Old 12-27-2012, 10:13 PM   #1 (permalink)
mxz700brp's Avatar
Mxz 700 Idle
I recently pirchased my first sled. 2000 MXZ 700. it runs well and is in good shape, im just reaching out to educate myself more about sleds. What should my sled idle at? if its too high, can i adjust the idle without having to re-sync the carbs?
mxz700brp is offline   Reply With Quote
Old 12-27-2012, 10:22 PM   #2 (permalink)
ride till your broke
Renagade's Avatar
welcome to the site.
your idle should be 1800-2000rpm's.
and you can adjust your idle, no prob.
current sleds
04 rev800ho gade
95 formulaIII 600
77 olympic 340e-mint!!
Old 12-27-2012, 10:37 PM   #3 (permalink)
mxz700brp's Avatar
so i can equally turn each of the two idle screws to reduce my idle? sounds easy enough.
Old 12-27-2012, 10:39 PM   #4 (permalink)
aduck's Avatar
If your idles hi I'd recommend cleaning the carbs real good.
93 mach1 670
02 rmk 800 162
95 powder special 580
Old 12-27-2012, 10:41 PM   #5 (permalink)
Renagade's Avatar
as long as u believe their in sync now ur fine.
current sleds
04 rev800ho gade
95 formulaIII 600
Old 12-27-2012, 10:55 PM   #6 (permalink)
mxz700brp's Avatar
i will try that. someone once told me to use lighter fluid to clean them? or should i just use carb & choke cleaner?
Old 12-27-2012, 10:58 PM   #7 (permalink)
mxz700brp's Avatar
yes i believe they are in sync now, (if they are not in sync whats the easiest way to tell) its runs strong with no hesitation. it just idles a lil high when i let off or when i come to a stop.
Old 12-27-2012, 11:44 PM   #8 (permalink)
aduck's Avatar
I use brake cleaner on my carbs unless carb cleaner is cheaper. Easiest easy to check sync is put your finger in the slide and gently squeeze throttle make sure they open together
93 mach1 670
02 rmk 800 162
Old 12-28-2012, 06:35 PM   #9 (permalink)
mxz700brp's Avatar
Cleaned the carbs, new plugs, and looked over the boots....idles @ 1900 now....
