Jumping speedometer needle - Snowmobile Forum: Your #1 Snowmobile Forum
Old 12-27-2012, 08:28 PM   #1 (permalink)
I have a 800 summit. The speedometer needle jumps from 0 to 120 while idling. Lights, tach and warmers all see to be ok. Any suggestions?
Sent from my DROIDX using Snowmobile.com App
bstuke is offline   Reply With Quote
Old 12-27-2012, 09:35 PM   #2 (permalink)
gbousum's Avatar
probably a bad speedo cable or bad speedo drive adapter, check those, in that order. Also, to make sure its not the speedometer itself, you can remove it and using a drill, stick the right size driver in the cable hole, run the drill and see what happens, be careful to not mess up the driver hole..
gbousum is offline   Reply With Quote
Old 12-27-2012, 10:06 PM   #3 (permalink)
aduck's Avatar
What year summit.
93 mach1 670
02 rmk 800 162
95 powder special 580
Old 12-28-2012, 01:01 AM   #4 (permalink)
The summit is a 04, rev. 800.
Old 12-28-2012, 06:50 AM   #5 (permalink)
If you idle it up a little does it stop?
Old 12-28-2012, 10:46 AM   #6 (permalink)
Idling it up, jumps it up to 120
Old 12-28-2012, 11:27 PM   #7 (permalink)
Update on the jumping speedo needle. Checked the relay found it ok. Needed to back the sled up to work on it. Crazy, it fixed itself. Speedo cable must have screwed up. Fingers crossed on staying fixed.
Thanks for the info!
Old 12-29-2012, 07:50 AM   #8 (permalink)
RXL
Fool Injected
RXL's Avatar
There is no cable on that machine... it has a speed sensor on the lower left side drive.
Check the plug for the speed sensor at lower left corner of the gas tank behind secondary and you may find some corrosion in it. If not check the plugs going to speedo and tach under the console to make sure they are tight.
RXL is offline   Reply With Quote
Old 12-29-2012, 07:59 AM   #9 (permalink)
TRH- Troll Raising Hell
JheLrey's Avatar
Why are you going to fast at idle? Sheesh!
Snow: The other white drug!
