95 Summit 670 won't run - Snowmobile Forum: Your #1 Snowmobile Forum
Old 12-26-2012, 01:40 PM   #1 (permalink)
Question 95 Summit 670 won't run
Hello,
I'm new to this forum. I would appreciate some help with a 95 summit 670 I am working on. Hopefully some of you have had similar probs.
Symptoms: was flooding crankcase, will run for a couple seconds then die, water in fuel.
repairs so far: new fuel pump, cleaned carbs and needle jets, checked bowl height, gas dryer in fuel.
I can get it to run with starting fluid for a few seconds, then it dies. Any feedback would be appreciated.
CJ Cycle is offline   Reply With Quote
Old 12-26-2012, 01:45 PM   #2 (permalink)
You could siphon out all of the gas or drain the gas. Then, put fresh gas in.
freaknyea is offline   Reply With Quote
Old 12-26-2012, 02:16 PM   #3 (permalink)
I don't know what the gas dryer is that you are referring to, but when you say water in gas... the first thing that comes to mind is put in new gas. I have had water in my motorcycle gas tank before. They bike would idle all day, but if I hit the throttle it would immediately cut out. If you have water in your tank your sled isn't going anywhere.
Old 12-26-2012, 03:13 PM   #4 (permalink)
I siphoned all the gas out. I am going to try that. Thanks for the help.
I put the mikuni fuel pump on it. I am just wondering if it is too small and not getting enough gas? I is the square pump with 2 outlets, 1 inlet and 1 suction.
Old 12-26-2012, 03:29 PM   #5 (permalink)
Unfortunately, I'm not familiar with the sled, so wouldn't know what to tell you in that regard. Maybe someone else can offer a little more information specifically to that. What kind of carb/pump should it have in it?
Old 12-26-2012, 06:06 PM   #6 (permalink)
If you replaced your fuel pump, you would have replaced it with the same size and style. Dual carb requires 2 outlets and a triple needs 3 outlets. Sounds to me you have the right one. Did you check your floats in the bowl? There is a high flow pump(65 litres/hr) and regular flow(31litres/hr). You can try googleing the specs for your sled or call a skidoo dealer. Sometimes priming the system will helpget the fuel flowing. Also check that your lines are running to the right location.
mikem is offline   Reply With Quote
Old 12-26-2012, 06:07 PM   #7 (permalink)
The pump should be OK. Drain the carb bowls and try again.
1999 Ski Doo Grand Touring
Old 12-26-2012, 06:12 PM   #8 (permalink)
Got it runnin, ran it around the place a few times. Shut it down and now I can't even get a hint of fire even with starting fluid. Checked spark and have that. Any other suggestions?
Old 12-27-2012, 04:51 PM   #9 (permalink)
bilbobagginz
try new plugs. i would have 2-3 sets.
bilbobagginz is offline   Reply With Quote
Old 12-28-2012, 06:53 AM   #10 (permalink)
Have you drained all the old fuel out? Are you draining the bowls?
