Formula z clicking - Snowmobile Forum: Your #1 Snowmobile Forum
Old 12-24-2012, 07:39 PM   #1 (permalink)
Formula z clicking
hi everyone so I have a 99 formula z 583 with 2800 miles I have a couple of questions when I am accelerating there is a range I would say 20-50mph(guess because its been a while sense ridden) but right in that range there is a loud clicking that happens it feels like it happens when the clutches move the sled performs fine just makes noise should I be worried? and the other question I have is what should the top rpm of this motor be mine likes to rev to like 8800 rpm not sure if that's bad thanks for any help
bill2014 is offline   Reply With Quote
Old 12-25-2012, 10:00 AM   #2 (permalink)
Check your track clips or a loose stud.
Old 12-25-2012, 03:06 PM   #3 (permalink)
davidnnoah's Avatar
8800 is too high. Your sled should like 7900. Clutches may be an issue.
http://webmn.alsa.org/site/TR/Rides/...nal&fr_id=8590
David H
Excelsior, MN
98 F3 600
97 Mach 1 700
95 MX 470
davidnnoah is offline   Reply With Quote
Old 12-25-2012, 05:53 PM   #4 (permalink)
ride till your broke
Renagade's Avatar
im thinking possibly primary clutch
has a problem. 8800 way to high.
current sleds
04 rev800ho gade
95 formulaIII 600
77 olympic 340e-mint!!
Old 12-25-2012, 07:18 PM   #5 (permalink)
ok thanks guys I am thinking it is probably the clutches just not sure where to start with it and why it would be reving up so high?
Old 12-25-2012, 08:45 PM   #6 (permalink)
Renagade's Avatar
well if i had to guess, the primary
clutch has sumthing broke in it??
causing the high rev situation.
current sleds
04 rev800ho gade
95 formulaIII 600
Old 12-26-2012, 01:01 AM   #7 (permalink)
No, check the secondary spring.
Make sure that it is adjusted properly
Old 12-26-2012, 08:17 AM   #8 (permalink)
davidnnoah's Avatar
While it wouldn't hurt to go through both clutches, you can isolate the issue with he marker check. Take a sharpie and draw a line on the inside of a sheave on both clutches. Take the sled out and wind it up. See which line is not completely worn off. That's where you start. Understand? Good luck either way.
David H
Excelsior, MN
98 F3 600
97 Mach 1 700
95 MX 470
Old 12-26-2012, 09:06 AM   #9 (permalink)
great il try that and yet u all know what the results are thanks for the help
Old 12-28-2012, 04:42 PM   #10 (permalink)
hey everyone so I found out some new information I took my sled for a long ride today and it is doing two different things now. the clicking has gotten less noticeable but I found it does not rev to 9000 instead it revs to 8. the problem I have is now half the time I go to stop the sled will only idle at 4000 rpm and the rest of the time it's normal also the thing feels really boggy once I pin it it feels strong for the first few seconds then bogs down anyone have any ideas
Old 12-29-2012, 09:12 PM   #11 (permalink)
found the problem one of the jets in the carb broke somehow
