I just installed a 2" block riser on my friends 02. We had to cut a couple of zip ties to get us a little extra length but no big deal. When I started to loosen the clamp bolts he had two of four nuts loose, when I put it back together I used a little loc tight on each bolt for good measure. Back to your original question, I would say a 2" riser would be max after that I would think you are looking at longer cables.
