What sled lines do you carry? I am just interested because right now my EFI cat is having some major power loss problems. The guys at the dealership have had it over a week and still can't seem to figure out what is wrong.
The sled looses power almost randomly... feels like it bogs down, but it doesn't sound like it is bogin down. It is unusual because if you let off the gas when it begins to bog down and then get rigt back on the gas... the engine fires right back up and continues to run like not a thing is wrong. It has become worse and worse... frist noticed it at speeds above 85 last year, and now it has gotten to the point that it does it at any speed. First they thought it was a bad clutch... replaced that... didn't fix it. Then they suspected the throttle safey switch (stops engine from starting is throttle is iced open) and that didn't fix it. They reported the computer checks okay.... any ideas / have you seen anything similar to this before?
Thanks
Mark
