1997 MXZ not running properly - Snowmobile Forum: Your #1 Snowmobile Forum
Old 11-25-2012, 12:45 PM   #1 (permalink)
Hi guys I am just new to this forum. I have a 1997 MXZ 440 fan cooled and went to fire it up for the first time this winter and it will run with the choke on but has a very low idle and bogs down with giving it some gas, and when i take the choke off it will fun for a little bit then die like it is running out of fuel. I put some gas line anitfreeze in it yesterday to see if it would make a difference and doesnt seem like it has. Just wondering if it is a carb problem or something elsle. I have owned the sled for 6 years now and havent done any maintenance on it since then, just plugs which I just put in a new set last winter. I did pull the plugs and found that one was dry and the other was wet. Thanks in advance for the advice.
pilsner_dude is offline   Reply With Quote
Old 11-25-2012, 01:00 PM   #2 (permalink)
aduck's Avatar
Pull the carbs and clean them! How old is the gas?
93 mach1 670
02 rmk 800 162
95 powder special 580
Old 11-25-2012, 01:22 PM   #3 (permalink)
I put 20 liters of new mid grade gas into it yesterday, had next to no gas left in it when I had parked it in the spring.
Old 11-25-2012, 02:46 PM   #4 (permalink)
aduck's Avatar
Good carb clean and you should be good
93 mach1 670
02 rmk 800 162
Old 11-25-2012, 06:36 PM   #5 (permalink)
X2 on carb clean. There is a tutorial in the how-to's section of this forum.
1999 Ski Doo Grand Touring
