1996 formula III clutch heat - Snowmobile Forum: Your #1 Snowmobile Forum
Old 11-20-2012, 01:30 PM   #1 (permalink)
codyccg's Avatar
hi guys my primary clutch is getting really hot for some reason and it says not to take it apart. what should i do?
codyccg is offline   Reply With Quote
Old 11-20-2012, 03:12 PM   #2 (permalink)
Check for belt slippage, and that it is aligned correctly and has the proper offset to the secondary.
Old 11-20-2012, 03:18 PM   #3 (permalink)
codyccg's Avatar
How do I align it? I'm sorry if that sounds dumb I'm new to sleds
Old 11-20-2012, 03:21 PM   #4 (permalink)
There is a tool that you can buy or just use a straight edge and measure offset.
You would have to check with a manual to get the right measurement.
Old 11-20-2012, 05:06 PM   #5 (permalink)
Make sure your engine mounts are not broken as well. Clutch heat is caused by belt slippage. Is the belt new?
1999 Ski Doo Grand Touring
Old 11-20-2012, 05:53 PM   #6 (permalink)
codyccg's Avatar
no the belt isnt new
Old 11-21-2012, 03:42 AM   #7 (permalink)
It's probably all glazed and slips now. The sides of the belt should NOT be all shiny.
Old 11-21-2012, 10:54 AM   #8 (permalink)
codyccg's Avatar
ok thanks!
Old 11-21-2012, 11:05 AM   #9 (permalink)
If the belt is shiny, use a wire brush or scotchbrite pad to the edge of it to roughen up the glaze. Make sure the clutch sheave faces are clean with no belt residue and rough those up with the scotchbrite pad as well. A rough surface tends to grip better so there's less slipping.
Old 11-21-2012, 11:41 AM   #10 (permalink)
codyccg's Avatar
ok i checked the belt out it wasnt too glazed. i cleaned the faces and the clutch is still getting hot
Old 11-22-2012, 09:41 AM   #11 (permalink)
Engine alignment issue. Did you check the mounts?
Old 11-22-2012, 10:09 AM   #12 (permalink)
codyccg's Avatar
yea the mounts are all fine
