04 Rev 800 X new owner need a little help - Snowmobile Forum: Your #1 Snowmobile Forum
Old 11-19-2012, 12:34 PM   #1 (permalink)
kjackson7710's Avatar
Hey guys, I purchased a 04 Rev 800 X at a auction the other day for the heck of it and I really dont know much about em. Says its an x package, what is different about the x package? what type of shocks are they supposed to have? What type of motor is this, SDI? are there any specifics I should check out that tend to fail on these sled? Any info. about them would help, I always rode cats but thought I would try this new fwd riding position to help my back out a bit. Thanks in advance for your help!
kjackson7710 is offline   Reply With Quote
Old 11-22-2012, 11:22 AM   #2 (permalink)
dboivin's Avatar
Originally Posted by kjackson7710 View Post
Hey guys, I purchased a 04 Rev 800 X at a auction the other day for the hell of it and I really dont know much about em. Says its an x package, what is different about the x package? what type of shocks are they supposed to have? What type of motor is this, SDI? are there any specifics I should check out that tend to fail on these sled? Any info. about them would help, I always rode cats but thought I would try this new fwd riding position to help my back out a bit. Thanks in advance for your help!
mainly xpackage shocks. early 800's had their issues. not as dependable as the 600's. 800s were suspect to crank and piston failures and recalls if i remember right. if your sled has over 4k miles on it, guessin it got it all straightened out. most blew before 2500.
dboivin is offline   Reply With Quote
Old 11-23-2012, 05:25 AM   #3 (permalink)
jeffcool326's Avatar
Excellent riding machine, bridges the gap between trail & mountain sled excellently. The only drawback I have encountered as many have found out with this machine is in order to insure longevity & durability one needs to change the carburetor specifications to the 2007 800HO P-Teks. The pilot jets need to be changed from the stock "05" #17.5 to the "07" #20 & turn the fuel screw out from 1.5 turns to 2.0 turns to cure the hanging idle problem. And the slides needles need to be updated to the "07" needle to fatten up the mid-range as the "05" carb needles are notoriously lean in the mid-range. Also special attention should be paid to the intake boots which are known to de-laminate & the exhaust Y pipes bolts are known to loosen. "Think Snow"
2005 Skidoo MXZ X 800ho Renegade
2005 Skidoo GSX 600 sdi
1998 Skidoo FormulaZ 583 Deluxe
1997 Skidoo MXZ 583
1996 Skidoo Touring LE
1996 Skidoo MXZ 500sls
jeffcool326 is offline   Reply With Quote
