rebuilding mach 1 700 - Snowmobile Forum: Your #1 Snowmobile Forum
Old 11-15-2012, 08:09 PM   #1 (permalink)
sebas7hekid's Avatar
i am curently rebuilding my mach 1 and i noticed on my cylinders that they are numbered from 1-3, just wondering which side of the motor is 1 clutch or pull cord side?
and if after im done putting it back together if i should do any speciel procedures before starting it? thank you
sebas7hekid is offline   Reply With Quote
Old 11-15-2012, 09:22 PM   #2 (permalink)
I just fix 'em...
IRONDOG's Avatar
There is no difference in any of the Mach 1 700 cylinders- there is no #1 cylinder. They will interchange in all positions.
www.snowmobileswapmeet.com
Old 11-16-2012, 03:54 AM   #3 (permalink)
Premix the fuel with oil as well for the first tank or 2.
1999 Ski Doo Grand Touring
Old 11-16-2012, 04:08 AM   #4 (permalink)
thank you for the help also. i have a rave valve that doesnt screw into the plastic part ill have to post some pictures, when i took it apart it was like that, there is just no threads on the inside, does any1 have that little black piece?
Old 11-16-2012, 04:16 AM   #5 (permalink)
here are two pictures of the part im talking about, i dont know if u can see that the threads are missing on the inside of picture 2 but there are none the rave valve itself usually screw into this piece. (there are other parts to this but they are all good if any more photos are needed i will get them)
rebuilding mach 1 700-snapshot_20121116.jpg   rebuilding mach 1 700-snapshot_20121116_1.jpg
Old 11-16-2012, 06:37 PM   #6 (permalink)
You need to replace that plastic cover. Someone reefed it down too hard and stripped it.
Old 11-24-2012, 07:48 PM   #7 (permalink)
SonofnIrishman
SonofnIrishman's Avatar
a
1997 Ski-Doo Mach 1 700 triple
Looking for reverse for this sled^^
SonofnIrishman is offline   Reply With Quote
Old 11-24-2012, 07:53 PM   #8 (permalink)
SonofnIrishman
I got that part from my local dealer. Don't remember how much it cost me, but it wasn't too bad I don't think. I've listed the part number below. I'm pretty sure that's what you're looking for.
P.N. 420 2532 57 Exhaust Valve Piston
Old 11-25-2012, 01:42 AM   #9 (permalink)
thank you every1 for the help, i replaced the rave valve, its was 30$ at dealer
