It is NOT required to split the cases on a 670 to change the rotary shaft seal. It can even be done with the engine in the chassis but it is easier with the engine out. Remove water pump cover, impeller and assorted washers, plate, etc., from front of the engine. Remove rotary valve cover, rotary valve and rotary seal retaining snap ring from rear of engine. Then drive the rotary shaft out from the front to the rear with a hammer and the proper tool. If you don't have the proper driver, use a 5/16" deep well 1/4" drive socket. You will want to replace the water pump seals as well while you are in there. This is a common procedure with Rotax rotary valve engines. It should be performed by an experienced mechanic to avoid any possible problems. It's easy screw this up if not done correctly.
