Well...took the reed valves out today & seems to me they might be toast ,can see gapes & slight artching of the pedels ,but not broke or cracked .Second ...took compression test before & after I took the reeds out no change , but it did read 100psi in both cylinders with 2 different compression testers
not so good!So I think this is all leading back to the no fuel problem that I have been having with the fuel pump .Pistons are not scored which are visable from the intake side .Don't know if the ring issues with this 2003 mxz rev were done or not now .? Sled has 2400miles. Any frigin input would be great right about now!...this sucks! One dead RXL ,one dead Ultra & now the Rev.... 6 more inches today of the white...I think I'm going to cry !
